It is currently Tue Aug 12, 2025 1:05 am
PostPosted: Thu Aug 25, 2016 7:56 am
Time for a fret slotting gang saw. A 25.5 board can be cut on a 34" scale saw, but from my figuring a 25" cannot be.
Two different arbors, correct?
Thanks all,
Matt
PostPosted: Thu Aug 25, 2016 10:24 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Correct.
http://www.mullinguitars.com/calculating-guitar-fret-spacing-fingerboard-dimensions-and-string-setback.html
PostPosted: Thu Aug 25, 2016 7:02 pm
First name: Fred
City: Winnipeg
I get the file is password protected, mind you using Microsoft Works.
PostPosted: Fri Aug 26, 2016 11:23 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Sorry you had trouble with this Fred. Many folks have used the spreadsheet zipped at this link, but I don't know if anyone has used Works.
The Excel workbook itself is not protected, but there are cells in the worksheet that are capable of having protection turned on -- basically all cells with the exception of user-input cells in blue. The cell protection currently has no password protection, so if you're asked for one, I suggest simply pressing "enter", but this really should only happen if you try to modify a non-blue cell.
Maybe someone else with Works can verify.
The purpose of pointing to the spreadsheet was as a tool to verify the OP's conclusion. Where he only requires the fret spacing for different scale lengths, the Stewmac online calculator can of course do the same thing.
